Interroga Posted April 30, 2018 Report Share Posted April 30, 2018 Its possible change collor in meter where the value reach adjustable value? Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 30, 2018 Report Share Posted April 30, 2018 Hi, Yes, it is possible to change the color of the fill according to its value, but only if the fill is solid. Look for a property called "Fill Solid" and check it. After you check it, then you should see that a new property called "Ranges" was added to the property grid. Click on the ... button, and define ranges of values with a fill color. Note: If the value is not within any range, it falls back to the pre-defined Fill Color. Quote Link to comment Share on other sites More sharing options...
Interroga Posted July 23, 2019 Author Report Share Posted July 23, 2019 On 4/30/2018 at 1:03 AM, Saragani said: "Fill Solid" thanks for reply. Quote Link to comment Share on other sites More sharing options...
