Downstream Posted June 8, 2018 Report Share Posted June 8, 2018 Ok, using this to create this. Which is exactly what I want, kind of... how do I add lines to the file to enter data into lines 2,3..... If I add more to the delimiter it fills in columns e,f,g ect. Can I copy line 1 too line 2 and then fill in data to line 1? if so, how? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 8, 2018 MVP 2021 Report Share Posted June 8, 2018 You probably need to enter a CR into one of your delimiter fields. Look at the posting suggestions- http://forum.unitronics.com/topic/5366-how-to-get-help-with-unitronics-products-dos-donts/ Your questions require us to see inside the blocks to determine their configuration. Upload your program. Joe T. Quote Link to comment Share on other sites More sharing options...
