kikep Posted August 6, 2018 Report Share Posted August 6, 2018 Ho w i can put a display and show as default default display when user select a idiom spanish or english and iven if i restar de plc or turn if going back to display can be possible. thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 8, 2018 MVP 2021 Report Share Posted August 8, 2018 Have you looked into how to use string libraries? You can have up to eight languages shifted into text objects on the same display, controlled by a numerical pointer. Joe T. Quote Link to comment Share on other sites More sharing options...
kikep Posted August 10, 2018 Author Report Share Posted August 10, 2018 I don't know how to put values on library to change the text on buttons , i have to display one is english and other is spanish but i would like when user click on change the display plc keep that as default display when turn off the plc..... Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 11, 2018 MVP 2021 Report Share Posted August 11, 2018 You do it here: It looks like you've accomplished your goal by making duplicate displays, which is another way. If you want to post your code I could configure a couple for you as an example. Joe T. Quote Link to comment Share on other sites More sharing options...
