Meetto Posted August 8, 2018 Report Share Posted August 8, 2018 Dear sir/Madam, I downloaded Uni logic latest version 1.24.56, keeping old version 1.18, the new version installed. it comes upto notifier then disappears. old and new both versions are not opening. Please help Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 8, 2018 Report Share Posted August 8, 2018 Did the old version (1.18) worked before installing 1.24.56 ? What Windows version you have? Quote Link to comment Share on other sites More sharing options...
Meetto Posted August 8, 2018 Author Report Share Posted August 8, 2018 Dear Sir/Madam, have good day. Yes earlier version was working. I programmed some programs and installed. My operating system is Windows 7 professional, 64 bit Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 8, 2018 Report Share Posted August 8, 2018 I see that you have contacted me in the past regarding this issue: I understood that the problem was solved after you have used System Restore. Please follow the following steps and tell me if it helped (and if so, which one). 1 ) Download and run the UniLogic Diagnostics" If it finds any problem, click on Fix, and try running UniLogic again 2) Download and run the following exe and see if it helps: https://dotnetbinaries.blob.core.windows.net/kbassets/KB4074906/fixittool-KB4074906.exe 3) If that doesn't help, then download and install .Net framework 4.7.1: https://download.microsoft.com/download/9/E/6/9E63300C-0941-4B45-A0EC-0008F96DD480/NDP471-KB4033342-x86-x64-AllOS-ENU.exe If none of the steps helped then tell me, and also contact our support in order to schedule a remote session. Quote Link to comment Share on other sites More sharing options...
Meetto Posted August 9, 2018 Author Report Share Posted August 9, 2018 Dear Saragani, have good day. Thank you for your kind assistance. I re insttales >NET frame work and software stated to work. Thanks again for kind help. Quote Link to comment Share on other sites More sharing options...
PMC11 Posted August 30, 2018 Report Share Posted August 30, 2018 Same issue ... on base OS, spalsh screen hangs on Loading Components... on VM workstation splash screen disappears Tried multiple re-installs/repairs... Both Win 7 SP1... Spent 1.5 hrs with remote support still no progress. Seems like a common problem based on forum... Quote Link to comment Share on other sites More sharing options...
PMC11 Posted August 30, 2018 Report Share Posted August 30, 2018 Downloaded and installed DotNet 4.7.1 in VM and it works!! Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 2, 2018 Report Share Posted September 2, 2018 OK, It was me with another R&D person, who remote sessioned your computer. The problem with the .Net framework is not so common. UniLogic requires .Net framework 4.6.2, but on some machines it doesn't work, and installing ,Net framework 4.7.1 solves the problem. I can only assume that the .net framework (4.6.2) was somehow not installed, or the installation was corrupted. I cannot longer check it since the .Net 4.7.1 uninstalls the previous version, but I'm glad that you managed to solve it. As for the problem with your main computer, this is very uncommon problem. The SQL Server Local DB installation does not work, at all! No instance manage to start, and it also fails on creating the instances. It fails on a function called "WaitForMultipleObjects". I've seen this kind of error in the past, but not on the creation of the instances, but rather while connecting the DB, so I'm not sure it's the same cause. Go to "Add/Remove Programs", and look for: AdAware or Web Companion. If you find any of these programs then uninstall them, Please write in this thread of you've found them or not. Another thing you can try: 1) Create a new user in your windows 2) Log in to that user 3) Start UniLogic Please tell me if creating a new user helped. It was suggested in several threads on other forums that it might work. (So if it does, then it can be a workaround). For example: https://dba.stackexchange.com/questions/30383/cannot-start-sqllocaldb-instance-with-my-windows-account Quote Link to comment Share on other sites More sharing options...
dhazelman Posted September 20, 2018 Report Share Posted September 20, 2018 I am also having problems with this software hanging on startup. The software hang on Loading Components... I am running Windows 10, 64 bit. I have attached the log files as a zip file.UniLogic logs.zip Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 25, 2018 Report Share Posted September 25, 2018 The error is: Error occurred during LocalDB instance startup: SQL Server process failed to start. I don't know if it's a specific error with the instance or with the entire sql server. You can try extracting the UniLogic Diagnostics in your installation directory and run it. Please tell me what it found (is the Red X appear on both Server and Instance?) Was it able to fix the problem? Quote Link to comment Share on other sites More sharing options...
