BobH Posted February 12, 2019 Report Share Posted February 12, 2019 Hello, I am a new programmer in Unilogics. After I got to know Unilogics , I have to set up an TCP/IP connection. The PLC is the server. I already programmed a function for sending information to the Hercules ( on my laptop). Now I need to receive information back from my Hercules. I have tried a lot of options but it will not work. The Rx blocks count the right amount of byte's that is received. The problem lays ( I think) in the fact that OUT E from the Rx box doesn't go to 1. Also I dont get BOX E from de parse message box. If i made a scanned message for receiving it isn't standing there. I find it very strange that i find it so easily to send info but then it wont work to receive info. thank you for the help in advance NOTE: " BUFFER ONTVANGEN MEANS BUFFER RECEIVED" im dutch haha Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 12, 2019 MVP 2021 Report Share Posted February 12, 2019 Moved to the correct forum. Please don't make duplicate posts. This board is moderated therefore it can take a bit before posts are approved. I'll leave this up since it includes more detail than the previous one. 1 Quote Link to comment Share on other sites More sharing options...
