Nassos.NET Posted April 16, 2019 Report Share Posted April 16, 2019 Hello to everyone, I have a SM35-J-T20 and a set two HSC as Counters and i notice that when there is a power-cut the DW values will reset to Zero. is there a way to avoid this reset? Thanks in advance, Nassos Quote Link to comment Share on other sites More sharing options...
Isakovic Posted April 16, 2019 Report Share Posted April 16, 2019 At the end of program (at the end of every scan) copy those registers into some other free DWs. Then at startup copy them back, via SB2 contact. I think there should be a complete example of this method somewhere in this forum, I've seen this topic before. 2 Quote Link to comment Share on other sites More sharing options...
Nassos.NET Posted April 17, 2019 Author Report Share Posted April 17, 2019 Thanks isakovic, i implemented your suggestion and worked great. Thanks again, Nassos Quote Link to comment Share on other sites More sharing options...
Mirko Posted May 28, 2020 Report Share Posted May 28, 2020 On 4/16/2019 at 10:11 AM, Nassos.NET said: Hello to everyone, I have a SM35-J-T20 and a set two HSC as Counters and i notice that when there is a power-cut the DW values will reset to Zero. is there a way to avoid this reset? Thanks in advance, Nassos On 4/17/2019 at 9:44 AM, Nassos.NET said: Thanks isakovic, i implemented your suggestion and worked great. Thanks again, Nassos On 4/16/2019 at 2:10 PM, Isakovic said: At the end of program (at the end of every scan) copy those registers into some other free DWs. Then at startup copy them back, via SB2 contact. I think there should be a complete example of this method somewhere in this forum, I've seen this topic before. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted May 28, 2020 MVP 2021 Report Share Posted May 28, 2020 @Mirko, are you having a problem we can help you with? This is your second post that just quotes others but has no content. Should I delete those? Quote Link to comment Share on other sites More sharing options...
