Dainius Vaskela Posted May 13, 2019 Report Share Posted May 13, 2019 Hi for all, I want to controll temperature with unitronics samba and now I use PID function block, set all configuration parameters, but controll value not changes. I don't have any idea how to do. Maybe someone can help me Quote Link to comment Share on other sites More sharing options...
Dainius Vaskela Posted May 13, 2019 Author Report Share Posted May 13, 2019 1 hour ago, Dainius Vaskela said: Hi for all, I want to controll temperature with unitronics samba and now I use PID function block, set all configuration parameters, but controll value not changes. I don't have any idea how to do. Maybe someone can help me Input J type termocouple and output need to be 0-10V Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 14, 2019 MVP 2021 Report Share Posted May 14, 2019 Call the A. TUNE CONFIG block with a normally open SB2 powerup bit. The config block is stomping all over your other PID blocks because it's always "configging". Joe T. Quote Link to comment Share on other sites More sharing options...
Dainius Vaskela Posted May 14, 2019 Author Report Share Posted May 14, 2019 So I do correction in the program, but it same. I change set point but controll value not changes. Quote Link to comment Share on other sites More sharing options...
Dainius Vaskela Posted May 14, 2019 Author Report Share Posted May 14, 2019 Work ! Thanks Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 14, 2019 Report Share Posted May 14, 2019 Great! Quote Link to comment Share on other sites More sharing options...
