OPC UA Certificate
Jakke_SL
Dear Jakke_SL,
The certificate you are creating in UniLogic is the OPC UA server one, meaning it will pass to OPC UA clients upon connection and help them identify the server identity.
The UniApps UI present OPC UA clients certificates that try to connect to your OPC UA server, meaning they will pass to your OPC UA server upon connection.
Try to connect with an OPC UA client to UniStream and you will see the client certificate on the UniApps UI.
