thmsbll Posted June 9, 2011 Report Share Posted June 9, 2011 Hello I am posting this because I have spent so much time trying to accomplish this on my own. I have an event I am trying to time and record in milliseconds. It is a leak test and I need to know the duration. I have the logic set up to start the timer, and to load the timer values into the SI140-143. And I have the display tagged to a variable that is tied to the MI I am using to store the timer value but I can't get the display to show the timer as it times. All it gives me is the preset. What is the magic that puts my timer timing up on the display. I can get a pulse timed counter to display, but this is not accurate enough. I think I am overlooking something. Scratching my Head. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 12, 2011 MVP 2021 Report Share Posted June 12, 2011 Which function number are you using? Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 13, 2011 MVP 2014 Report Share Posted June 13, 2011 If you link the actual timer rather than the MI value, you will have many options, see below: Quote Link to comment Share on other sites More sharing options...
