leen Posted February 7, 2020 Report Share Posted February 7, 2020 Hi, I read in an input. Every second the value of the input ( 0 or 1) stored in an array. After 1 minute I have 60 values into the array list. Then I want to calculate the average value of all values to know how many times the input is high into 1 minute. But there is no function to get direct the result, only i.e. to get the minimum or maximum value. To calculate on a way by 1 to 1 it's very long-winded. Is there a function what I can use or a simply way to fixe this. Best regards Leen Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 7, 2020 MVP 2021 Report Share Posted February 7, 2020 Just use the INCrement function to count them into an MI. Quote Link to comment Share on other sites More sharing options...
