V230 Using Labview DSC and Modbus
Do some digging on NI's website for the LabView code.
Here's the Modbus library:
LabView Modbus Libary 1.21
Be sure to read the user comments about a bug in one of the vi's.
Here's NI's Modbus introduction:
NI Modbus intro
Assuming the V230's will be slaves, all you have to do on the Unitronics side is configure the Ethernet port, trigger a Modbus IP configuration block with SB 2, and hang a Modbus IP ScanEX block on the rail.
