Charlesc Posted April 27, 2020 Report Share Posted April 27, 2020 Hi Have a problem to copy my data table on my dok. First i copy my data table on the sd with the bloc "store dti to file" and after i use the bloc copy/move to transfer the value on my dok. But the statuts stay always at -3 ( invalid dok folder path) And i use the syntax given in help. On location D i write #"DT/" Thanks for help Quote Link to comment Share on other sites More sharing options...
NoamM Posted June 30, 2020 Report Share Posted June 30, 2020 Dear Charlesc, Do you have a folder name "DT" on your DOK/USB Stick root? Quote Link to comment Share on other sites More sharing options...
