damiankk Posted September 28, 2020 Report Share Posted September 28, 2020 Hi, I consider few ways to get 100 variables every second from USC-B10-TR22: 1. Create DataTable on SD card, and then get it through FTP server 2. Get data via MODBUS 3. Use any OPC client When I tested first way, there was problems with accurate timming. I forced creating line in SD file with data every 0.8s, and average time was around 0.8s, but varied between 0.6 and 1.4s Second way seems to be ok, but using Python's modbus library also occured some timming mismatch. Average was also ok, but again varied between similiar values. I'm not sure, but it also can be Python's library problem, because it is me first time with this library. So far I don't have any experience with OPC and I would like to know is it right way or not. I also tried DataSampler, but it is limited by amount of variables saved with one DataSampler, so I discontinued this way. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 29, 2020 Report Share Posted September 29, 2020 hi damiankk, in my opinion with 100 variables you can use the modbus way...what you have to be sure is that at the PC side the python scrip has to use an asynchronous method. I am not so deeply inside python but I found THIS example about how to implement an async modbus_TCP_client. 1 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted September 29, 2020 Report Share Posted September 29, 2020 orso2p001 Is you link for Linux-like PCs? "#!/usr/bin/env python" damiankk - How about to use SQL database connection? You can create data table and add records with time stamp. Then use this information as you wish. B.R. 1 Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted September 29, 2020 Report Share Posted September 29, 2020 2 hours ago, AlexUT said: Is you link for Linux-like PCs? ...I took the first exampke that I found searching "pythin async modbus client" without any checks...😀 Quote Link to comment Share on other sites More sharing options...
damiankk Posted September 30, 2020 Author Report Share Posted September 30, 2020 Thank You for replies. I'm going to check both ways. After first try SQL looks friendly Quote Link to comment Share on other sites More sharing options...
