MrEngineer Posted October 22, 2020 Report Share Posted October 22, 2020 Hello there! I'm looking for a way to set two time variables that can be set on HMI and the third time variable which would be the sum of T1 and T2 ... Is there any easy way to do it? Here's a quick (BUT WRONG) representation of the idea: Thanks in advance! KR Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted October 22, 2020 MVP 2021 Report Share Posted October 22, 2020 Just use "Load Timer/Counter Preset" under the Store menu. Also, be aware that you can't activate a Delay Timer (TD) with a transition contact. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted October 22, 2020 MVP 2021 Report Share Posted October 22, 2020 Oops, forgot a step. Need to do the Store Timer/Counter Preset after the addition. 1 Quote Link to comment Share on other sites More sharing options...
MrEngineer Posted October 22, 2020 Author Report Share Posted October 22, 2020 Thank you! Solved the problem 👌 Quote Link to comment Share on other sites More sharing options...
