sasdiscos Posted October 25, 2020 Report Share Posted October 25, 2020 Hello all. In vision I created a simple DST add subtract and put a button on the screen. Attached picture. Is there any way of doing this in unistream? I can't seem to get it to work. Many thanks, Steve Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 25, 2020 MVP 2021 Report Share Posted October 25, 2020 There's a Daylight Savings time program in the Examples. Note that this program requires the PLC to be powered up when it's time to change the clock. Joe T. Unistream_070_Daylight_saving_time.ulpr Quote Link to comment Share on other sites More sharing options...
sasdiscos Posted October 31, 2020 Author Report Share Posted October 31, 2020 Cheers Joe. I just saved the rtc to another location variable and then used the add minus function, redirected all my rtc stuff to look at the new variable. Steve Quote Link to comment Share on other sites More sharing options...
