MVP 2021 kratmel Posted October 28, 2020 MVP 2021 Report Share Posted October 28, 2020 USP -070-B10 panel used as VNC client started with black screen. I prepare recovery DOK with 1.28.58 firmware as this version it used for program PLC with the same panel+CPU as server. After sucessfull recovery - USP -070-B10 show Connecting frame and do not connect with server PLC. I try to disable VNC client mode but as i see it is not possible. Connecting frame still on screen. I can select System, Network, Utilites at time approx 0.5 sec after start and Connecting screen lock all function. Machine work with server PLC but remote panel do not work now. Maybe something wrong with settings now but i can't chane it. Unilogic say Download and Online mode are not supported for USL and Unistream PLC's acting as ones. Any idea? Maybe i lost something in manual or help? How to disable VNC on USP? P/S Change firmware for another version do not change panel behavior. Quote Link to comment Share on other sites More sharing options...
DanT Posted October 28, 2020 Report Share Posted October 28, 2020 Hi Kratmel; Can you get into the UniApps from the Screen and check the VNC Settings? DanT Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted October 28, 2020 Author MVP 2021 Report Share Posted October 28, 2020 1 hour ago, DanT said: Can you get into the UniApps from the Screen and check the VNC Settings? No, screen react only for 0.2-0.5sec. and i can only change System, Network, Utilites menu but no information prsent. Connecting frame run on screen. UniApps start not posible. All touch is interrupted by Connecting frame. Also try with mouse... no result. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 1, 2020 Author MVP 2021 Report Share Posted November 1, 2020 Unitronics support help to solve issue via remote connection. After that, according to the recommendations i download blank project and panel restart to normal mode. Thanks to the Unitronics support for a quick solution! Quote Link to comment Share on other sites More sharing options...
