mari720413@gmail.com Posted October 29, 2020 Report Share Posted October 29, 2020 Hello, recently I buy modem CINTERION EHS6T USB. Firmware is 04.013. I have tried to configure modem via VisiLogic and normally it does not happened because firmware has to be 03.001. Unfortunately there is no way to know which firmware will be when you purchase. And usually there are updates for this kind of hardware. Do you have some updates in AT lines for this model? Shall GSM-KIT-16J KIT ,BGS2T be work with USP-104-B10? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 29, 2020 Report Share Posted October 29, 2020 Hi, You have to buy modems from Unitronics to use with Unitronics PLCs. This will warrant that modem will be compatible with PLCs. Or Unitronics will clearly state what is not supported. CINTERION EHS6T USB, Firmware is 04.013 is a re-designed modem with some major changes in hardware and software. It is not sold by Unitronics and will not work with Unitronics PLCs. It is recommended to return this modem to dealer. Please review newluy introduced by Unitronicvs Router. This Router is a 2G, 3G, 4G, LTE modem-router and supporting many functions. Links: https://www.unitronicsplc.com/support-technical-library/ Scroll to "Accessories", then expand "Routers". There are 2 models with variations for different countries. Hope this information helps. B.R. Alex. Quote Link to comment Share on other sites More sharing options...
mari720413@gmail.com Posted November 19, 2020 Author Report Share Posted November 19, 2020 Hello again. Now I have original Kit. At the end I have this message. What can I do. Best regards Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 19, 2020 Report Share Posted November 19, 2020 When you scroll down to next strings: You can see that default baudrate is set to 115200. If you wish to use 9600 in Ladder, you have to change default baudrate to 9600 and then run Init Modem. As well, set communoication baudrate to 9600 as well. After Prepare modem will remember baudrate 9600. B.R. Quote Link to comment Share on other sites More sharing options...
mari720413@gmail.com Posted November 19, 2020 Author Report Share Posted November 19, 2020 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 19, 2020 Report Share Posted November 19, 2020 Is SIM card activated and inserted right way? Do you use 9 pin RS232 male to female cable to make Prepare? Quote Link to comment Share on other sites More sharing options...
mari720413@gmail.com Posted November 19, 2020 Author Report Share Posted November 19, 2020 Hello. Yes! Yes! Even those messages modem works on my USP-104-B10. Where can i find more detailed information about sending and receiving SMS except help in unilogic . Do you have some examples of using I/O of modem ,lets say for getting calls. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 19, 2020 Report Share Posted November 19, 2020 UniStream PLCs make modem initialization by itself. SMS Send/Receive supported. In GPRS mode you can send emails and use TCP/IP based protocols. Calls are not supported. What is a modem job in your project? Or you just investigate modem features? B.R. Quote Link to comment Share on other sites More sharing options...
