LE BERRE Posted December 1, 2020 Report Share Posted December 1, 2020 Chers tous, J'essaye de sauvegarder les données avec la date et la date. Par exemple : je voudrais enregistrer une valeur comme UINT16 chaque jour et faire un DTI avec les 365 jours de l'année et enregistrer la mise Le DTI ressemblera à ceci: rangée valeur Date 1 12 01/02/2020 2 52 02/02/2020 3 65 03/02/2020 4 78 04/02/2020 5 92 05/02/2020 6 15 06/02/2020 La meilleure économie sera à minuit. Et je voudrais enregistrer si le processeur est allumé si sur la ligne du DTI sera vide. Je ne sais pas si c'est possible? BR Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted December 2, 2020 MVP 2021 Report Share Posted December 2, 2020 Definitely possible. If you look in the UniStream examples (separate download) there is something to convert the current date to an ASCII string which you can store in your table. Include the "PLC on at Midnight" bit in your Data Table. I'd include a string of the time as well. You can use the RTC Schedule function to trigger your Data Table write. I would set a bit when I wrote the table and then look later in the day with another Schedule block or when the PLC powers up to make sure it was set. If it's set, you clear it. If it wasn't set, you could write a line to the Data Table showing it wasn't set. If you're having trouble with the code, post it here and we'll have a look. Joe T. Quote Link to comment Share on other sites More sharing options...
