TozoM8 Posted January 6, 2021 Report Share Posted January 6, 2021 I've had it working a while back, but I can't connect now. Plc up 192.168.1.2 all sockets are initialized. Plc name is same. Plc is plunged into a switch. My laptop is also plugged into the same switch and able to connect via Ethernet. I can't get it to work on the phone. What gives? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 6, 2021 MVP 2021 Report Share Posted January 6, 2021 First thing I would check is to make sure the phone and PLC are on the same subnet. Likely your phone is connected via wi-fi and routers tend to hand out IP addresses to wi-fi on a different subnet than on the wired output. Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted January 7, 2021 Author Report Share Posted January 7, 2021 My phone shows 192.168.68.110 I've tried 192.168.68.100 on the plc side, but didn't work. Quote Link to comment Share on other sites More sharing options...
