Antal 0 Posted January 14 Report Share Posted January 14 Hello Support don't answer, I need help. USC-B10-B1 so far i have used version 1.30.62 Unitronics UniLogic everything is fine. I downloaded version 1.31.106 today. This error occurs several times after each update, not even the PLC goes.This is an error message. I put back the old version it works fine. Thank you in advance for your answer. Regards B.A Quote Link to post Share on other sites
Ausman 209 Posted January 14 Report Share Posted January 14 Antal, I don't see that image.....only "image.png" cheers, Aus Quote Link to post Share on other sites
Antal 0 Posted January 15 Author Report Share Posted January 15 Hi Ausman I hope it will be good now. Regards B.A Quote Link to post Share on other sites
Ausman 209 Posted January 15 Report Share Posted January 15 The screen basically says all that is needed. There is a saying on the forum that if you don't need to update, don't do it. If you need a particular feature that is only available in a later version, by all means update, but be prepared to possibly change something using the later version you use. Although in the Vision forum, this pinned post says it all. https://forum.unitronics.com/topic/7245-dont-update-just-because-you-can/?do=findComment&comment=29557 cheers, Aus Quote Link to post Share on other sites
Antal 0 Posted January 15 Author Report Share Posted January 15 Ausman I read what is on the link. Thanks for the good advice. Regards B.A Quote Link to post Share on other sites
