Rümeysa Arslan Posted February 17, 2021 Report Share Posted February 17, 2021 Hello everyone! I have 30 pcs of sm35-j-ra22 plc and they are all connected to ethernet line. I want to view and control the data I get from these on the USP-156-B10 HMI Panel. How can I do that? I think i have to use "Scanner Adapter" and define all of SM35 PLC's ip. 1 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 17, 2021 Report Share Posted February 17, 2021 SM35 series PLCs does not support Ethernet/IP. You have to use MODBUS TCP. *Only UniStream series PLCs supporting Ethernet/IP. 1 Quote Link to comment Share on other sites More sharing options...
Rümeysa Arslan Posted February 17, 2021 Author Report Share Posted February 17, 2021 Hi Alex, so how can i do that ? Thanks for your answer. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 17, 2021 MVP 2021 Report Share Posted February 17, 2021 Take a look at this and see if it helps you: 1 Quote Link to comment Share on other sites More sharing options...
