Rümeysa Arslan Posted February 17, 2021 Report Share Posted February 17, 2021 Hello everyone! I have 30 pcs of sm35-j-ra22 plc and they are all connected to ethernet line. I want to view and control the data I get from these on the USP-156-B10 HMI Panel. How can I do that? I think i have to use "Scanner Adapter" and define all of SM35 PLC's ip. 1 Link to comment Share on other sites More sharing options...
AlexUT Posted February 17, 2021 Report Share Posted February 17, 2021 SM35 series PLCs does not support Ethernet/IP. You have to use MODBUS TCP. *Only UniStream series PLCs supporting Ethernet/IP. 1 Link to comment Share on other sites More sharing options...
Rümeysa Arslan Posted February 17, 2021 Author Report Share Posted February 17, 2021 Hi Alex, so how can i do that ? Thanks for your answer. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 17, 2021 MVP 2023 Report Share Posted February 17, 2021 Take a look at this and see if it helps you: 1 Link to comment Share on other sites More sharing options...
