Patrick Posted March 29, 2021 Report Share Posted March 29, 2021 Good morning everyone, Is it possible to edit the display format (or add a new one) in in a Timer Variable? I want to display time remaining on the screen in seconds and 1/10 second as displaying 1/100 flickers. Cheers Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 29, 2021 MVP 2021 Report Share Posted March 29, 2021 Use the function "Load Timer/Counter Current", divide by 10, then display as you would any other number, selecting one decimal place. 1 Quote Link to comment Share on other sites More sharing options...
Patrick Posted March 30, 2021 Author Report Share Posted March 30, 2021 Thank you @Flex727 that worked perfectly! The bonus being I can now display other timers in the same sequence, in the same spot, by using the same operands. Quote Link to comment Share on other sites More sharing options...
