Gili Posted April 10, 2021 Report Share Posted April 10, 2021 I want to do the following : when A>B -> SET , when A<B -->RESET. B in a constant value and A is a flout. how to use the float compare operator? why there are any difference between the compare int and compare float? Thanks! 0 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 11, 2021 MVP 2021 Report Share Posted April 11, 2021 Yes, there is a difference. You don't need the additional SET coil of MB 9 on the float block. The output of the instruction is stored in MB 9 as you've shown. Your logic as written will always set MB 9. Your INT compare is correctly done. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
