innov8 Posted April 11, 2021 Report Share Posted April 11, 2021 Hi, I would like to store the date & time an alarm occurs, and display the previous couple alarms with their respective timestamps. It would be nice to have the most recent alarm at the top of this list. Anyone have an example or ideas how to go about this using a Jazz controller? Thanks! Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 12, 2021 Report Share Posted April 12, 2021 Hi, Jazz OS has no embedded support for Alarms. You have to realize it by yourself, or use other PLC model with embedded alarms support. It is recommended to review example projects to find one which fitting your needs. B.R. Quote Link to comment Share on other sites More sharing options...
innov8 Posted April 12, 2021 Author Report Share Posted April 12, 2021 Thanks. I understand that there’s no specific alarm function built into this system. I was wondering if anyone has done it anyhow, and how they went about it. My application is pretty simple and has been functioning quite well for several years now, so I’m not changing that out. Quote Link to comment Share on other sites More sharing options...
sgull Posted April 12, 2021 Report Share Posted April 12, 2021 In the examples that come with the program installation there is an application called "Alarms with time stamp" This is in the database folder "Normally" at this location C:\Program Files (x86)\Unitronics\Unitronics U90 Ladder\Examples\Data base It might help to achieve what you need. Quote Link to comment Share on other sites More sharing options...
