sasdiscos Posted May 11, 2021 Report Share Posted May 11, 2021 Hi all. Is there an option to remotely mount the cpu on a hmi. When installed it makes it very deep. Thanks, Steve Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted May 11, 2021 MVP 2021 Report Share Posted May 11, 2021 It is not possible. High speed CPU to panel connection and power must be as short as possible. Maybe best solution - use Unitronics panel (VNC) and Unisteam PLC without HMI (Virtual HMI). https://www.unitronicsplc.com/unistream-series-plc/#1449515769763-3521ed84-35551451602511853 Quote Link to comment Share on other sites More sharing options...
