M91 Ladder Proofing
I've got two portions of a project that are similar. One operates correctly and the other goes through the timing logic, but no output is fired. I'm not certain if I'm using the MB improperly or if there is some protocol I'm missusing. Can I send the ladder to someone or insert it here, somehow, for someone to review?
Do a screenshot and post it to an imaging hosting site such as photobucket.com. Then insert the link to your image in the post.
One way I use to see if logic is solving is to use a SET coil assigned to a test MB. If the coil doesn't get set, there's something wrong with the logic in front of it.
