RAIHAL1 Posted June 23, 2021 Report Share Posted June 23, 2021 Hi, Is there simulator available ? What I have found it's third party product. Which company has developed it ? For me it doesn't matter if I have paid for it. Link below doesn't work. >There is a simulator offered by an independent developer in our PLC Market. Note that this is not a Unitronics product. Check it out here: http://www.plc-apps.com/collections/apps-for-pc /R Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 23, 2021 MVP 2021 Report Share Posted June 23, 2021 If you search this forum you will find that this has been asked and answered many times. The bottom line is that there is no software simulator available. It is recommended that you purchase a PLC for your software development. This is usually a cheaper solution than other manufacturers' simulators and is guaranteed to be 100% accurate in the simulation. Unitronics PLCs are designed to operate without the associated I/O for the programmer's convenience (and cost saving). When you consider that the PLCs are inexpensive and the programming software is free this is a workable solution. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 23, 2021 Report Share Posted June 23, 2021 Do not count on this simulator. Better work with a real PLC. Quote Link to comment Share on other sites More sharing options...
