example programm for queue managmant in in unistream
didi
Hi didi,
i think that you are talking about a feeding system that has to works in FIFO mode...right?
I suggest to use a DTI where you insert the receivers that need to suction and a counter, that you will increase/decrease, about the DTI position to insert or remove.
then, if necessary, move the receiver of row 0 in the "working flow".
10 hours ago, didi said:
In each demand part must turn on vacuum valve
I build 8 channel feeder from one vibratory bowl.
Main problem - what system must do if two or more receivers send signal at the same time.
In my case i must build something like that
You can see - system has channel activation priority and must switch off all active switch.
  • Like 1
