Juho Sainio Posted November 28, 2021 Report Share Posted November 28, 2021 Hello, I have a problem getting a pt-100 3 wire sensor to work with my unitronics plc V350-35-TU24. Despite all of my efforts, it still shows the value 32767. Here is my setup right now: This is how the jumper settings should look like for pt-100: https://imgur.com/a/Q73WbcY Here is how they are on my plc: https://imgur.com/a/HAhDQpk This is how the pt-100 wire connection should look like: https://imgur.com/a/e55mO8O And the connection on my plc: https://imgur.com/a/vpn97Ld The software configurations look like this: https://imgur.com/a/EjbkioB And after downloading it to the plc, the online test shows the error value: https://imgur.com/a/SZrL3Eq I have also tried other wire connections like this one: https://imgur.com/a/6LuGb8q But this one also shows the same error value. The pt-100 sensor also works perfectly fine: https://imgur.com/a/6FzEM5d Is there something I'm missing? What should I try to get it to work? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 28, 2021 MVP 2021 Report Share Posted November 28, 2021 Terminals 7 & 8 are Analog Input 1, not Analog Input 0. Just move your wire connections over to 5 & 6. 1 Quote Link to comment Share on other sites More sharing options...
Juho Sainio Posted November 28, 2021 Author Report Share Posted November 28, 2021 I was tunnel visioning while following the "IO Webinar" youtube video. Now it works!😄 Thank you for the quick reply. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 28, 2021 MVP 2021 Report Share Posted November 28, 2021 👍 Quote Link to comment Share on other sites More sharing options...
