MVP 2021 Flex727 Posted December 1, 2021 MVP 2021 Report Share Posted December 1, 2021 I opened an older project file this morning and it opened with none of the contact or coil symbols visible. Since then, all my project files look like this. I've tried opening files in other VisiLogic versions (using Version Swapper) and everything now looks like this. Anyone ever seen this? Anyone have an idea of what the cause or fix might be? I am using Windows 10 on a high-resolution monitor. I've tried changing display resolution and font size, but no improvement. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 1, 2021 Author MVP 2021 Report Share Posted December 1, 2021 I usually have a zillion windows and applications open that I am working on simultaneously, all set up the way I like, so rebooting the computer is always a last resort. I finally gave in an closed everything down and rebooted. Happily, that fixed the problem. Sure is a weird problem though and it would be nice to understand the cause. Quote Link to comment Share on other sites More sharing options...
John_R Posted December 1, 2021 Report Share Posted December 1, 2021 I had this happen a couple years ago, I don't remember the exact reason, but it was a Windows video driver thing.... Quote Link to comment Share on other sites More sharing options...
