wbarkley Posted December 4, 2021 Report Share Posted December 4, 2021 I've been racking my brain on getting a timer to send a pulse to a decrement counter. My goal is to have a counter that decrements every hour while the timer/clock is active. Any thoughts would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 4, 2021 MVP 2021 Report Share Posted December 4, 2021 You just need a self-resetting timer, thus: Quote Link to comment Share on other sites More sharing options...
wbarkley Posted December 4, 2021 Author Report Share Posted December 4, 2021 Thank you. I realized I had made a rooky mistake. I'm using a TA timer and had placed the reset coil before the counter and the timer would not receive the pulse. I moved the reset to a net below the counter and its working perfectly now. Quote Link to comment Share on other sites More sharing options...
