Fennel Posted January 23 Report Share Posted January 23 Hello I've tried to download a test project on a brand-new plc (US5-B10-RA28) and got a message that I won't be able to do it until the controller OS is updated. So I did it following the help instructions. I used a 16 GB DOK with FAT32 and started an update via UniApps. After about 20min I got an error message saying that the update has failed. I restarted the PLC by turning it off and on (because I couldn't do it from the UniLogic) and verified that the PLC sees the USB stick and update files of it. This time I started the process again, but using "Remote Update" in UniLogic. The update is going on for about 4-5 hours, so I suppose it will never finish. UniLogic version: 1.32.61 Firmware I'm trying to install: 1.32.63 Unfortunately, I don't remember the firmware that the PLC had, I think it was 1.25 Any suggestions? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted January 23 MVP 2021 Report Share Posted January 23 Hi, after OS update process we can find normal updated PLC, not updated (update filed but PLC in working condition), not updated - PLC is not started. Standard update process: https://support.unitronics.com/index.php?/selfhelp/view-article/upgrade-or-downgrade-unistream-panel If PLC do not start: https://support.unitronics.com/index.php?/selfhelp/view-article/rescue-procedure-to-recover-unistream-panels If you have problems with standard update - I recommend changing the USB DOK to another new one from another manufacturer. If the process of updating a new PLC has not taken place - you can change the PLC to a new one under warranty. If your attempts are unsuccessful, and you can't quickly replace the controller - I recommend contacting the manufacturers - they have quality online support. https://support.unitronics.com/index.php? Qualified Unitronics employees can remotely check the upgrade process and fix your problem. 1 1 Quote Link to comment Share on other sites More sharing options...
Fennel Posted January 24 Author Report Share Posted January 24 Eventually it worked with the "Forced" unchecked. Quote Link to comment Share on other sites More sharing options...
