Donovan Posted January 31, 2022 Report Share Posted January 31, 2022 I am wondering if there is a way to determine which panel is currently being displayed by using the ladder? I want to perform an action if a specific panel is being displayed. I know in u90 ladder it's a comparison check with a system integer value, but couldn't find anything similar in Unilogic. Thanks! 🙂 Quote Link to comment Share on other sites More sharing options...
Dave Posted January 31, 2022 Report Share Posted January 31, 2022 You can assign a tag to the "Is Active" property of each screen. Then use that tag to trigger an action, defined in the Actions section of the Solution Explorer 1 Quote Link to comment Share on other sites More sharing options...
