Upload Attempts exceeded - How to Reset Upload Option
paulm
  • 2 weeks later...
50 minutes ago, TomasB said:
Please can you describe me how to do "Power cycle of PLC"?
It means turn it off and back on again.
What about program / data tables / PLC blocks / timers...? Stay this data inside PLC after this reset?
Normally, all data is retained during a power cycle if the battery is good. If you're uncertain about the battery, you can do a "RESET" without removing power and that will do the same thing. RESET can be performed from VisiLogic or from INFO Mode (it can also be performed from ladder if it is written in the program).
  • Thanks 1
