Tumminello calogero Posted June 13 Report Share Posted June 13 buon giorno devo collegare ad una pompa un misuratore di litri ho un plc v700 come posso fare il odice e la finestra x visualizzare il codice, e a quale porta sara ingput grazie Tumminello C. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 13 Report Share Posted June 13 Move to Vision topics. Translation (probable with some errors): capture npn square wave pulse signal. how to code the window x display the value. good morning I have to connect a liter meter to a pump I have a plc v700 how can I do the odice and the window to view the code, and at which port it will be ingput Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted June 13 MVP 2021 Report Share Posted June 13 Hi, to solve your problem, you must specify which set of inputs / outputs, ie expansion modules or snap module is present. It is impossible to solve your problem by using only the V700 controller without additional expansion (or SNAP-ON) units. Since you have an NPN logic pulse signal that must be applied to the logic input and this input should preferably be HSC compatible input. Quote Link to comment Share on other sites More sharing options...
Tumminello calogero Posted June 14 Author Report Share Posted June 14 buon giorno io ho un v200-18-e4xb e devocollegare un misuratore di portata della Riels rif 400 , il manuale dice segnale impulsi onda quadra NPN e possibile avere un esempio un mini programmno cosi vedo come fatto e in quale porta collegare il cavo di segnale . grazie Quote Link to comment Share on other sites More sharing options...
Tumminello calogero Posted June 21 Author Report Share Posted June 21 il mio v700 ha 4 porte analog outputs 15 porte digital outputs 4 porte analog inputs 15 porte digital inputs sigla come accennato PLC+HMI V200-18-E4XB Quote Link to comment Share on other sites More sharing options...
