Marcelo Posted July 1, 2022 Report Share Posted July 1, 2022 Hello, Im having some issues to do this task on unilogic. Will thank any help you could give me. I need to block the screen and the execution of the program every month for a full year and the only way to unlock this is filling a Password wich has to be diferent for each month. Tried to make this work with RTC.Date blocks but its a very long codding and the idea its to make it as simple as possible to avoid slowing the program execution. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted July 1, 2022 MVP 2021 Report Share Posted July 1, 2022 Hi, you can find idea in this topic Ausman find ladderart solution in Visilogic ladder subroutine that can be imported to blank project. You can implement the same idea for your project in Unilogic Quote Link to comment Share on other sites More sharing options...
