Admin vs tester feature -->Password Level
  • 2 weeks later...
I am a bit surprised by your question.
If I have a PLC for testing, the tester is default user. Why the separate role of the tester - to limit access to the PLC to everyone else except the tester?
If so, then the task is solved simply - the first password that the system asks for is entering the tester mode (working mode). Only after entering this mode - we have the opportunity to enter administrator mode by selecting the settings button and entering the administrator password while in tester mode.
That is, two buttons are available to the tester - TEST and SETTINGS - but he gets there only after entering the administrator's password.
P.S. Hide option is present is button properties.
  • Like 1
