CallMeGeorge Posted August 30, 2022 Report Share Posted August 30, 2022 I'm working with an existing machine. I have zero experience working with Unilogic, except for one hour of monitoring the logic on this same machine. I only need to edit a recipe file on the SD card. I don't need to change the PLC program. Presumably I can locate the recipe file on the SD card; copy the file to my laptop; edit the file; copy the file back to the SD card. I'm not seeing anything in the help system that talks about accessing files on the SD card outside the PLC program. Can someone point me in the right direction? Thanks. Quote Link to comment Share on other sites More sharing options...
CallMeGeorge Posted August 30, 2022 Author Report Share Posted August 30, 2022 I suppose the simple solution is to remove the SD card and plug it into the laptop... Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted August 30, 2022 Report Share Posted August 30, 2022 Probably you would need Unistream Data Converter Suite (https://www.unitronicsplc.com/Download/SoftwareUtilities/UniStream_Data_Converters_Suite_1_0_18.zip) to get access and convert datatable to Excel to be able to modify it. Quote Link to comment Share on other sites More sharing options...
CallMeGeorge Posted August 30, 2022 Author Report Share Posted August 30, 2022 32 minutes ago, Gabriel Franco said: Probably you would need Unistream Data Converter Suite (https://www.unitronicsplc.com/Download/SoftwareUtilities/UniStream_Data_Converters_Suite_1_0_18.zip) to get access and convert datatable to Excel to be able to modify it. Thanks for the info. I have downloaded the utility. Looks pretty straightforward. Quote Link to comment Share on other sites More sharing options...
NoamM Posted September 5, 2022 Report Share Posted September 5, 2022 Hi CallMeGeorge, In order to access the PLC SD card from a PC you can use the 'FTP Server' Once the FTP Server is set, you can access the data on your SD using FTP Client (for example FileZilla) running on your PC. Quote Link to comment Share on other sites More sharing options...
CallMeGeorge Posted September 7, 2022 Author Report Share Posted September 7, 2022 Thanks, NoamM, that's good to know. Turns out that the pertinent information in the file on the SD card originates in a remote database, having been retrieved earlier in the process via a SQL command. So, the fix was to update the information in the database; the PLC program did not need to change. I appreciate the help received. Quote Link to comment Share on other sites More sharing options...
