Linearize Multiple Inputs
Hi.
I want to use an M91 to dynamically linearize two analog inputs, perform some math on the results and then use those results to linearize one analog output.
I have seen the sample ladder code, using SI 80 thru SI84, and the trigger bit SB80.
I don't have an M91 handy to test this so my question is...
If I set all the values into SI80-SI84, then set bit SB80, then store the SI85 value to an MI, immediately after setting the SB80 bit, will it actually store the linearized value, or does the program need to complete another scan after setting the SB80 bit, before performing the linearization?
