MELDAW Posted December 20, 2022 Report Share Posted December 20, 2022 Hello, I am actually using UNITRONICS Panel USC-104-B10, I have a problem with configuring the TON function, everytime I try to configure i find that instantly the current and the preset are equal, and i can't configure the bit OUT. Any idea for how i can configure that? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 20, 2022 MVP 2021 Report Share Posted December 20, 2022 Timers count DOWN and the Out Bit will turn on when the Current value reaches zero. 1 Quote Link to comment Share on other sites More sharing options...
MELDAW Posted December 20, 2022 Author Report Share Posted December 20, 2022 Ok I will try to test it again, thank you for your reply. Quote Link to comment Share on other sites More sharing options...
MELDAW Posted December 21, 2022 Author Report Share Posted December 21, 2022 Okay I got it but I have another question, if i want to give the timer a value from a table, can it be done? I tried but the current value always stuck. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 21, 2022 MVP 2021 Report Share Posted December 21, 2022 The STORE function should work for that. You can store a value into either the Preset or Current for the timer. Quote Link to comment Share on other sites More sharing options...
