RickL Posted February 26 Report Share Posted February 26 Hello! I blu thru my allotted upload file size to forum. : ( .... when does this limitation reset? Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted February 26 MVP 2021 Report Share Posted February 26 @Cara Bereck Levy can we possibly do something about limits on the forum being increased. Perhaps link it to number of posts, to cover potential over-use? And an FYI for all, I use XnConvert to very easily reduce jpg file and physical sizes for forum use. I have saved a setting that gets an ideal output. Very easy program to work with, and very good at what it does. cheers, Aus Quote Link to comment Share on other sites More sharing options...
RickL Posted March 1 Author Report Share Posted March 1 On 2/26/2023 at 4:31 PM, Ausman said: @Cara Bereck Levy can we possibly do something about limits on the forum being increased. Perhaps link it to number of posts, to cover potential over-use? And an FYI for all, I use XnConvert to very easily reduce jpg file and physical sizes for forum use. I have saved a setting that gets an ideal output. Very easy program to work with, and very good at what it does. cheers, Aus I did as you recomended - XnConvert download. Can you share the ideal setting you found? Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted March 2 MVP 2021 Report Share Posted March 2 My settings will be irrelevant for you. You need to tailor your own based on what the original source size and type will be. Most of my pics are screenshot conversions, but the initial size is still different dependant on your PC. Quote Link to comment Share on other sites More sharing options...
