RickL Posted March 9 Report Share Posted March 9 Hello! I need to have the always visible "Water Level Sensor" toggle button be password protected before its allowed to be activated (toggled on). The four buttons on the left are normally "invisible" and set the fixed operational parameters. They are only visible when "water level sensor" button is toggled on. Can this type button be password protected? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 9 MVP 2021 Report Share Posted March 9 Of course. I password protect buttons and screens all the time. There are various ways to do it, but VisiLogic has a password HMI element built right in. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted March 9 Report Share Posted March 9 You can use "Disabled Mode" option of the button and then reset its linked bit after password is entered. Quote Link to comment Share on other sites More sharing options...
RickL Posted March 9 Author Report Share Posted March 9 I got it now! working great! ........ this feature is all assigned from the HMI. I preferred to have the parameter set buttons just disappear when not required. Press: Set-up Parms button Password : 1234 Pump PLC V.3.vlp Quote Link to comment Share on other sites More sharing options...
