How to copy program from Unitronics V1040 to another V1040 using Visilogic
Dear Sir.
I have two devices with the same function, each controlled by a Unitronics V1040. Currently one device is not working due to a program problem, I want to copy the program from a device that is running well to install on the device that is broken. This is my first time with unitronics, please help me. Thank you very much .
There is an Upload program function in VisiLogic to allow you to upload the program from the PLC to VisiLogic, but unless the original programmer downloaded the program with the Upload project function enabled, it cannot be done.
Just go to Connection / Upload while connected to the PLC and see if it lets you.
  • Like 1
