Mac9010 Posted July 11, 2023 Report Share Posted July 11, 2023 Good day everyone! I have a little project and I would like to use a Samba 4.3 PLC, but I don´t know if it has I/O modules extra. I need around 25 Inputs and 15 outputs. I hope that you can help me! Thanks in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted July 11, 2023 MVP 2023 Report Share Posted July 11, 2023 Samba offer only 12 inputs and 8 outputs. No direct I/O expansion module connection possible. Possible solution - Samba CAN module + EX-RC1 modue + 8 I/O module. 1 Quote Link to comment Share on other sites More sharing options...
DanT Posted July 11, 2023 Report Share Posted July 11, 2023 Hi Mac; SM43-J-R20 or T20 has Fixed I/O is designed not to be expanded using standard IO-xxx Modules. The SAMBA Series in a subset of the Vision Series, meant for simple self contained projects. You will have to go upto a Full Vision Model. V430-J-R34 22 Inputs, 12 Relay Out EX-A2X Expansion Adapter IO-DI8-RO8 8 Inputs, 8 Relay Out ( EX-DI8-RO8 is an option -- Fixed I/O Expansion 8 In, 8 Relay Out ) You can also consider Kratmel's solution, but you have to re-adjust all the Canbus Struct Addressing to make it work. Another Method is using the remote I/O - SAMBA + Ethernet Module + URB-TCP2 + IO Modules. Again it is the programming overhead to make it work. These are for more experienced Unitroncis programmers who know the tricks from experience. SAMBA has limited Programming memory. DanT 2 Quote Link to comment Share on other sites More sharing options...
Mac9010 Posted July 12, 2023 Author Report Share Posted July 12, 2023 Kratmel and DanT. Thank you for your recommendations Have a nice week. 🖐️ Quote Link to comment Share on other sites More sharing options...
