Gabriel Franco Posted July 31 Report Share Posted July 31 Is it possible to keep forces after power-up? I´m using USP-070-B10 + USC-P-B10 with some IO. Forced some inputs and outputs via Uniapps but after power-up all forces are deleted. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted July 31 Report Share Posted July 31 Hi Gabriel i think that you have to use retain variables...so you haven't to write directly on the IO but you have to set the variables..then in some points of your project check the value of the variable and set the IO. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted August 3 Author Report Share Posted August 3 To whom may be interested: answer from Unitronics Support: "No option to force on power up, you can configure a tag with power up value and store the value to the output". Quote Link to comment Share on other sites More sharing options...
