MVP 2022 Ausman Posted August 23 MVP 2022 Report Share Posted August 23 For those of us who still occasionally need Win XP, and even those using virtual machines where actual activation makes things simpler, a hack has appeared that makes it easy. It isn't a crack as such, it imitates phone activation. I recently had to do a complete reinstall on a different system to run some older stuff, and activation was needed. There are various references to the file online, but the small .exe is squirrelled away a bit. No doubt it will become more obvious as time goes on, but if anyone wants it, change .txt to .exe on the attached file. It can interact with the XP system so that there is no manual input needed. Perhaps it even has it's origins from M$0ft, but who really knows. cheers, Aus xp.txt Quote Link to comment Share on other sites More sharing options...
