MELDAW Posted October 9 Report Share Posted October 9 Hello Everyone, I have a problem, I need to do a communication between my TA30 and another machine, with RS485 but the problem is the machine is sending a function 08 so the PLC can't recieve this communication is there a solution for this problem? Thank you Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted October 9 MVP 2022 Report Share Posted October 9 You can try to use Message composer. Please see link to example in this topic Quote Link to comment Share on other sites More sharing options...
MELDAW Posted October 10 Author Report Share Posted October 10 Thank you for your reply, But the message Composer is for the CPU right? How can i send it with Tx? Quote Link to comment Share on other sites More sharing options...
