Parrey Posted October 19 Report Share Posted October 19 I am new to this, just got given a m91-2-ra22 unit and been asked to get the program from the plc. I have 24v power supply connected to the top input and it power and i can communicate with it over rs232. The unit is showing system fault. Power in failure. Is there a way to fix this? Ive never used these units before. Thank you Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 19 Report Share Posted October 19 5 hours ago, Parrey said: The unit is showing system fault. Power in failure. 1. "unit is showing system fault" - How fault looks? 2. "Power in failure" - How failure looks? Is this related to p. 1? Pictures, text, more explanation... 3. When this fault happens? 4. Is this setup new or old? 5. Being this setup working before? 6. How problem started? Details, details, details... Quote Link to comment Share on other sites More sharing options...
MVP 2022 Ausman Posted October 19 MVP 2022 Report Share Posted October 19 As you can communicate via 232, in theory you can use U90 to try and get the program out of the unit for you to then examine. If successful, I am guessing that one of the inputs is used to monitor whether power of a certain type is on, and this is raising what I think will be a screen that is part of the user program in the unit. As Alex says, not quite enough detail. U90 has lots of help to assist your learning. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Parrey Posted October 29 Author Report Share Posted October 29 Sorry i have been away and have just got home. I was able to pull the program off using rs232. I have a look into the program and in6 was a power failure relay which was checking for 24v. I added a 24v input to it and the errors went away and i was able to use the unit fully. Thank you all for your help Quote Link to comment Share on other sites More sharing options...
