cuongvcs Posted October 25 Report Share Posted October 25 Dear all. I have the project to convert from V280 to V570(V280 discontinuous). And get some issued with the PID function. The error "PID CONFIG : not support by color PLC or/and V130-33" The error "PID RUN : not support by color PLC or/and V130-33" can you pls help me to solve this issued. thank you so much. Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted October 25 MVP 2022 Report Share Posted October 25 Swap out the Function blocks for the ones under "PID Autotune". Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 25 Report Share Posted October 25 After converting project you have to replace all "PID" functional blocks to a new "PID Auto-tune". Quote Link to comment Share on other sites More sharing options...
cuongvcs Posted October 26 Author Report Share Posted October 26 On 10/11/2023 at 7:14 PM, Ausman said: Without the password you are in trouble. However, was the Visilogic programming done using a company computer that still exists? If so, the actual project might still be in the computer, and you will then have a copy. Check the name of the project in the PLC by using Info mode to try and match it up to any remaining projects in the computer. Use the Help file in Visilogic to find out how to access Info mode. But Info mode might also have a non-standard password, it all depends on what the original programmer did. Also check whether there is a project copy on the mini SD card if one is fitted in the PLC. 11 hours ago, Flex727 said: Swap out the Function blocks for the ones under "PID Autotune". 11 hours ago, AlexUT said: After converting project you have to replace all "PID" functional blocks to a new "PID Auto-tune". Dear All friend. Let me try. thank you so much. BR Quote Link to comment Share on other sites More sharing options...
